Disable UDP Connection
sorset
Post by sorset » Mon May 06, 2013 9:26 am
Hello
For some reason , I should connect VPN through proxy , so I should force client to make TCP based connections , if not , connection will be closed before it be established.And I should retry about ten times to establish TCP conenction!
Is there any way to disable UDP or force client to make TCP connection? or make TCP in higher priority?
barrierfr
Re: Disable UDP Connection
Post by barrierfr » Tue May 07, 2013 5:05 am
Well yes you can do this. However it's depend on how you use the software client prospective but here I guess you use the software using openvpn client : you have to update the vpn client file and replace "proto udp" by "proto tcp". don't check the box udp on the openvpn MS-STTP clone server function setting.
rgds
Fred.
sorset
Post by sorset » Tue May 07, 2013 8:22 am
Thank you , but I'm Using Packetix Tunnel. Isn't there any way to do that?
Post by cedar » Tue May 07, 2013 4:59 pm
Please append '/tcp' after the server host name in a connection setting.
sorset
Post by sorset » Tue May 07, 2013 8:41 pm
Thank you a lot , cedar . worked fine :-)
