NEW FIREWALL in IRAN problem solved, please read
				freeiran
your softether at first chek open connection to conne
				Lord Farhad
Re: NEW FIREWALL in IRAN problem solved, please read
Thanks for the information and robotic English.
				freeiran
it is easy
strat ccproxy on your server.
make ccproxy account and connect through http proxy on client of softethet on 443.
then coneect to hostname 127.0.0.1.
then go advanced setting
change connections to 8, disable encryption, enabale compression, use half duplex, disable voice qos.
finished
it is easy
finished
				Phoenix
salam freeiran
If that really worked, can you write a tutorial or break it into more steps?
tnx in advance
tnx in advance
				freeiran
i explanied all of them
				freeiran
say me which part you have problem
				Phoenix
the part about ccproxy username
				freeiran
you should install ccproxy software on the server and make a user name on that
				Lord Farhad
OK here is the deal, correct me if I'm wrong:
1. CC proxy server on 443 port with a username.
2. SoftEther client connects to HTTP proxy via 443, then connects to localhost in proxy again on 443 which is the SoftEther VPN server.
it is not working, I can connect to proxy but it didn't pass the pinging google.com test. (no internet in proxy)
any special config in CCproxy server, server binding, port setting or something? since both SoftEther and CC proxy are listening to 443.
Edit:
After spending hours of testing I can confirm there is no way for both CC Proxy and SoftEther to work in conjunction of each other on the same port (443).
there is also seems to be a conflicting problem with SoftEther SecureNat and CC Proxy, currently I'm unable to get CC Proxy work with it's default setting. it's kind of the same scenario with Kerio Control 7 & CC Proxy:
Connection establishes to CC Proxy server, user authentication works but CC Proxy fails to transport the internet witin proxy tunnel.
dear freeiran, please supply us with your CC Proxy and SoftEther configuration, if possible attach your config files of both programs with random IPs.
Edit:
