Until some days ago the service worked fine in Iran but now it is fake-working!
The connection and authentication procedure goes well and the connection shows working but neither the IP is changed nor the filter is bypassed in action. It seems that he software is hacked someway?!
The VPN client shows connected but the IP is not changed!
PersianUser
Re: The VPN client shows connected but the IP is not changed
Even if the session is valid, it does not mean the network is available.
Please make sure that an IP address is assigned to a virtual network adapter, and the default gateway is configured.
PersianUser
Thanks a lot cedar!
I checked the tcp/ip settings of virtual network adapter and found that the automatically acquire IP option is deactivated! (Really don't now how), after activation the problem solved and the IP changed.
