Hello, i´m having trouble to make my server stable, I figured out that if I use the regular way to connect to server (using the list from vpngate), the connect drops as soon as it connect to server BUT if I make the manual connection and disable the UDP Acceleration everything goes fine. I think everyone that is trying to connect to my server ends up disconnected as soon as it request the IP from DHCP.
I edited the config file and set the "DisableUDPAcceleration true" on server but it doesn´t work.
Thank you very much.
