Problem with connecting via OpenVpn
miximixi
Post by miximixi » Fri May 17, 2013 9:33 am
Hi there...
I've configured SoftEther to accept OpenVpn.
Then download OpenVpn client for windows and place config file(the one that i downloaded from softether app - openvpn_remote_access_l3).
now it can't connect and wait on log page. here are what on log are appear.(i replaced my ip with x.x.x.x)
Fri May 17 13:38:36 2013 OpenVPN 2.3.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [IPv6] built on Mar 28 2013
Fri May 17 13:38:36 2013 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25341
Fri May 17 13:38:36 2013 Need hold release from management interface, waiting...
Fri May 17 13:38:36 2013 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25341
Fri May 17 13:38:36 2013 MANAGEMENT: CMD 'state on'
Fri May 17 13:38:36 2013 MANAGEMENT: CMD 'log all on'
Fri May 17 13:38:36 2013 MANAGEMENT: CMD 'hold off'
Fri May 17 13:38:36 2013 MANAGEMENT: CMD 'hold release'
Fri May 17 13:38:41 2013 MANAGEMENT: CMD 'username "Auth" "miximixi"
Fri May 17 13:38:41 2013 MANAGEMENT: CMD 'password [...]'
Fri May 17 13:38:41 2013 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Fri May 17 13:38:41 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri May 17 13:38:41 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri May 17 13:38:41 2013 MANAGEMENT: >STATE:1368781721,RESOLVE,,,
Fri May 17 13:38:42 2013 UDPv4 link local: [undef]
Fri May 17 13:38:42 2013 UDPv4 link remote: [AF_INET]x.x.x.x:443
Fri May 17 13:38:42 2013 MANAGEMENT: >STATE:1368781722,WAIT,,,
Fri May 17 13:38:42 2013 MANAGEMENT: >STATE:1368781722,AUTH,,,
Fri May 17 13:38:42 2013 TLS: Initial packet from [AF_INET]x.x.x.x:443, sid=903398d3 c6130e68
Fri May 17 13:38:42 2013 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Fri May 17 13:39:42 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri May 17 13:39:42 2013 TLS Error: TLS handshake failed
Fri May 17 13:39:42 2013 SIGUSR1[soft,tls-error] received, process restarting
Fri May 17 13:39:42 2013 MANAGEMENT: >STATE:1368781782,RECONNECTING,tls-error,,
Fri May 17 13:39:42 2013 Restart pause, 2 second(s)
Fri May 17 13:39:44 2013 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Fri May 17 13:39:44 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri May 17 13:39:44 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri May 17 13:39:44 2013 MANAGEMENT: >STATE:1368781784,RESOLVE,,,
Fri May 17 13:39:44 2013 UDPv4 link local: [undef]
Fri May 17 13:39:44 2013 UDPv4 link remote: [AF_INET]x.x.x.x:443
Fri May 17 13:39:44 2013 MANAGEMENT: >STATE:1368781784,WAIT,,,
Fri May 17 13:39:45 2013 MANAGEMENT: >STATE:1368781785,AUTH,,,
Fri May 17 13:39:45 2013 TLS: Initial packet from [AF_INET]x.x.x.x:443, sid=f5f6b1a9 d420d220
Fri May 17 13:40:44 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri May 17 13:40:44 2013 TLS Error: TLS handshake failed
Fri May 17 13:40:44 2013 SIGUSR1[soft,tls-error] received, process restarting
Fri May 17 13:40:44 2013 MANAGEMENT: >STATE:1368781844,RECONNECTING,tls-error,,
Fri May 17 13:40:44 2013 Restart pause, 2 second(s)
Fri May 17 13:40:46 2013 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Fri May 17 13:40:46 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri May 17 13:40:46 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri May 17 13:40:46 2013 MANAGEMENT: >STATE:1368781846,RESOLVE,,,
Fri May 17 13:40:46 2013 UDPv4 link local: [undef]
Fri May 17 13:40:46 2013 UDPv4 link remote: [AF_INET]x.x.x.x:443
Fri May 17 13:40:46 2013 MANAGEMENT: >STATE:1368781846,WAIT,,,
Fri May 17 13:40:46 2013 MANAGEMENT: >STATE:1368781846,AUTH,,,
Fri May 17 13:40:46 2013 TLS: Initial packet from [AF_INET]x.x.x.x:443, sid=ca15b309 1e800519
Fri May 17 13:41:46 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri May 17 13:41:46 2013 TLS Error: TLS handshake failed
Fri May 17 13:41:46 2013 SIGUSR1[soft,tls-error] received, process restarting
Fri May 17 13:41:46 2013 MANAGEMENT: >STATE:1368781906,RECONNECTING,tls-error,,
Fri May 17 13:41:46 2013 Restart pause, 2 second(s)
Fri May 17 13:41:48 2013 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Fri May 17 13:41:48 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri May 17 13:41:48 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri May 17 13:41:48 2013 MANAGEMENT: >STATE:1368781908,RESOLVE,,,
Fri May 17 13:41:48 2013 UDPv4 link local: [undef]
Fri May 17 13:41:48 2013 UDPv4 link remote: [AF_INET]x.x.x.x:443
Fri May 17 13:41:48 2013 MANAGEMENT: >STATE:1368781908,WAIT,,,
Fri May 17 13:41:48 2013 MANAGEMENT: >STATE:1368781908,AUTH,,,
Fri May 17 13:41:48 2013 TLS: Initial packet from [AF_INET]x.x.x.x:443, sid=89e5d46b 2ff6c4b0
Fri May 17 13:42:48 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri May 17 13:42:48 2013 TLS Error: TLS handshake failed
Fri May 17 13:42:48 2013 SIGUSR1[soft,tls-error] received, process restarting
Fri May 17 13:42:48 2013 MANAGEMENT: >STATE:1368781968,RECONNECTING,tls-error,,
Fri May 17 13:42:48 2013 Restart pause, 2 second(s)
Fri May 17 13:42:50 2013 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Fri May 17 13:42:50 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri May 17 13:42:50 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri May 17 13:42:50 2013 MANAGEMENT: >STATE:1368781970,RESOLVE,,,
Fri May 17 13:42:50 2013 UDPv4 link local: [undef]
Fri May 17 13:42:50 2013 UDPv4 link remote: [AF_INET]x.x.x.x:443
Fri May 17 13:42:50 2013 MANAGEMENT: >STATE:1368781970,WAIT,,,
Fri May 17 13:42:51 2013 MANAGEMENT: >STATE:1368781971,AUTH,,,
Fri May 17 13:42:51 2013 TLS: Initial packet from [AF_INET]x.x.x.x:443, sid=7c947475 427de0d2
Fri May 17 13:43:50 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri May 17 13:43:50 2013 TLS Error: TLS handshake failed
Fri May 17 13:43:50 2013 SIGUSR1[soft,tls-error] received, process restarting
Fri May 17 13:43:50 2013 MANAGEMENT: >STATE:1368782030,RECONNECTING,tls-error,,
Fri May 17 13:43:50 2013 Restart pause, 2 second(s)
Fri May 17 13:43:52 2013 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Fri May 17 13:43:52 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri May 17 13:43:52 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri May 17 13:43:52 2013 MANAGEMENT: >STATE:1368782032,RESOLVE,,,
Fri May 17 13:43:53 2013 UDPv4 link local: [undef]
Fri May 17 13:43:53 2013 UDPv4 link remote: [AF_INET]x.x.x.x:443
Fri May 17 13:43:53 2013 MANAGEMENT: >STATE:1368782033,WAIT,,,
Fri May 17 13:43:53 2013 MANAGEMENT: >STATE:1368782033,AUTH,,,
Fri May 17 13:43:53 2013 TLS: Initial packet from [AF_INET]x.x.x.x:443, sid=22396933 3c70c26e
Fri May 17 13:44:54 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri May 17 13:44:54 2013 TLS Error: TLS handshake failed
Fri May 17 13:44:54 2013 SIGUSR1[soft,tls-error] received, process restarting
Fri May 17 13:44:54 2013 MANAGEMENT: >STATE:1368782094,RECONNECTING,tls-error,,
Fri May 17 13:44:54 2013 Restart pause, 2 second(s)
Fri May 17 13:44:56 2013 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Fri May 17 13:44:56 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri May 17 13:44:56 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri May 17 13:44:56 2013 MANAGEMENT: >STATE:1368782096,RESOLVE,,,
Fri May 17 13:44:56 2013 UDPv4 link local: [undef]
Fri May 17 13:44:56 2013 UDPv4 link remote: [AF_INET]x.x.x.x:443
Fri May 17 13:44:56 2013 MANAGEMENT: >STATE:1368782096,WAIT,,,
Fri May 17 13:44:56 2013 MANAGEMENT: >STATE:1368782096,AUTH,,,
Fri May 17 13:44:56 2013 TLS: Initial packet from [AF_INET]x.x.x.x:443, sid=6a9d5773 036f4637
Re: Problem with connecting via OpenVpn
Post by cedar » Fri May 17, 2013 11:27 am
Did you checked a log-file on VPN server?
miximixi
Post by miximixi » Sat May 18, 2013 12:56 pm
where is that!?
Post by cedar » Sun May 19, 2013 8:44 am
Log files can be read in VPN Server manager.
You can also find log files in install folder.
Lord Farhad
Post by Lord Farhad » Sun May 19, 2013 8:38 pm
try Viscosity.
