big difference between softether vpn and other vpn
freeiran
Post by freeiran » Sat May 18, 2013 5:57 pm
hi
i founded that for example when i connect with windows VPN my default route deleted and a new route written that send any to my vpn, but softether doesnt do that.
does it possible to do this such as other vpns?
when softether doesnt have this option there are some techniques to filter softether.
dear admin i am waiting for your reply
thanks
Re: big difference between softether vpn and other vpn
Post by cedar » Sun May 19, 2013 8:43 am
If Default gateway is set in the virtual network adapter, Windows will use it.
This is an OS function instead of a function of SoftEther VPN.
freeiran
Post by freeiran » Sun May 19, 2013 10:51 am
i know what you said and windows write new route, but in windows vpn windows delete old default route and after disconnect the vpn rewrite that again, but softether doesnt delete the old route
Post by cedar » Sun May 19, 2013 3:21 pm
More than one default gateway can't be enabled at the same time.
Windows uses the default gateway for the network adapter with the lowest interface metric.
