problem: VPN bridge connection very very slow
sirase
Post by sirase » Mon May 20, 2013 6:22 am
Hi, I'm sirase.
I installed VPN Server [softether-vpnserver-v1.00-9091-rc3-2013.05.19-linux-x86-32bit.tar.gz] and
VPN Client [softether-vpnclient-v1.00-9091-rc3-2013.05.19-linux-x86-32bit.tar.gz].
The VPN Server is Virtual Machine that is Debian Wheezy[7.0] 32bit on VMware ESXi.
The VPN Client is Physical Machine that is Linux mint MATE Nadia[14] 32bit.
I setup VPN Server bridge mode. And I connect this server from my local machine(Linux mint MATE).
Success connection and I can transfer file using CIFS protocol.
I open FileManager[Caja 1.4.0], type address bar [smb://192.168.1.101], hit Enter.
I send local machine to remote machine(192.168.1.101) dummy file.
This is NO PROBLEM. File transfer speed is 840KB/s. fast enough.
BUT, I receive from remote machine to local machine, VERY CRITICAL PROBLEM APPEARD.
File transfer speed is 4.5KB/s. It is VERY VERY SLOW speed!!
Of course, on direct connection or OpenVPN connection's speed is fast.
Please tell me how to fix this critical problem.
Maybe SoftEther's bug ?
-- add --
This problem appeard bridge mode only.
Tunneling mode doesn't appeard this problem.
Re: problem: VPN bridge connection very very slow
Post by cedar » Mon May 20, 2013 2:50 pm
Why do you use CIFS to copy the files?
CIFS is slow in WAN generally.
Please try to use FTP or HTTP.
sirase
Post by sirase » Mon May 20, 2013 4:13 pm
Thank you reply.
I know CIFS is slow via WAN as you sed.
BUT, local -> remote CIFS protocol file transfer speed is 840KB/s.
Remote -> local CIFS protocol file transfer speed is 4.5KB/s.
This result CLEARLY STRANGE. Not the cause CIFS protocol.
I test RDP protocol too.
My local machine to remote machine(bridged LAN's other Windows7 machine).
The result is very slow remote access.
Very slow refresh monitor.
Clearly remote -> local VPN throughput(download speed) is very very slow.
I hope help.
Thanks.
-- add --
Added test via HTTP protocol.
The result is same, 4.5KB/s slow Download.
Thanks.
Post by cedar » Thu May 23, 2013 12:56 pm
I think the network you are using asymmetrical from the original.
If network speed is unusually slow, packet loss is suspected.
Please measure the packet loss rate by using a tool such as ping.
sirase
Post by sirase » Mon May 27, 2013 11:00 am
cedarさん
返信ありがとうございます。
この掲示板全体が英語インタフェースな上、過去のcedarさんの
書き込みもちらっと見た限り英語だったので、慣れない英語を無理して
使っていたのですが、日本語ネイティブに話せる方のようで・・・。
今更ですが日本語で書かせて頂きます。
pingでテストしてみてとのことですが、下記の結果です。
$ ping -c 4 192.168.1.101
PING 192.168.1.101 (192.168.1.101) 56(84) bytes of data.
64 bytes from 192.168.1.101: icmp_req=1 ttl=64 time=43.1 ms
64 bytes from 192.168.1.101: icmp_req=2 ttl=64 time=43.2 ms
64 bytes from 192.168.1.101: icmp_req=3 ttl=64 time=43.2 ms
64 bytes from 192.168.1.101: icmp_req=4 ttl=64 time=43.0 ms
--- 192.168.1.101 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3002ms
rtt min/avg/max/mdev = 43.032/43.190/43.285/0.231 ms
パケットロスは無いので、何か別の原因でしょうか・・・・。
クライアント側のインターネット回線と、サーバ側のインターネット回線は
それぞれ光ファイバーなので、上りも下りも高速です。
VPNサーバ側がESXi上のDebianであるという点のみが少し特殊かとは思いますが
ESXiの設定でプロミスキャスモードを許可に設定することで問題なくブリッジ接続
自体は出来ています。速度だけなぜか非常に遅いのです。
クライアントからみてのダウンロード速度、サーバから見てのアップロード速度が遅いです。
過去の
http://www.vpnusers.com/viewtopic.php?f=7&t=1608
このPostを読ませて頂きましたがどうも違う原因のようです。
藁をもすがるような思いです。よろしくお願い致します。
# cedarさんって登大遊さんだったりします?
sirase
Post by sirase » Mon May 27, 2013 12:39 pm
解決しました。
原因はESXiの仮想マシンの設定の中で、NICの設定をする箇所が
あるのですが、そのNICを E1000 に設定していた事のようです。
この仮想NICを一度削除し、もう一度NICを追加して今度は「フレキシブル」
に設定すると、正常に高速転送出来るようになりました。
しかしESXiで仮想マシンのタイプを「Debian 6 32bit」と設定すると、「E1000」か
「VMXNET3」の2つしか選択出来ず、しかもデフォルトが「E1000」になっているので
そのまま特に何も考えず仮想マシンを作成していました。これを、一度
仮想マシンのタイプを「その他のLinux 32bit」に設定して、「フレキシブル」のNIC
を追加した後、「Debian 6 32bit」に戻してあげる事で本件解決しました。
ESXi依存の問題だったのにSoftEtherの問題だと思い色々お騒がせ致しまして
申し訳ありませんでした。レス下さったcedarさん、ありがとうございました。
