question about bridge service
freeiran
hi admin
i setup a bridge between softether client and server, and have ping beetween them, also i set an ip address from on layer3 virtual interface and have ping from client to this adapter, but i cant route the bandwidth from server that has internet to the virtual interface of layer3.
can you help me about that?
i should do this work bevause of my server softeare is on VPS and hyper-v in win 2003 doesnt have promiscuous mode to enable.
dera admin, i am waiting for your reply
best regards
best regards
Re: question about bridge service
What is your goal?
What purpose do you want to use the VPN for?
freeiran
i want to make a vpn on bridge, and then route some IP addresses from server to client trough the tunnel
Is it correct in understanding that you want to build a network, such as the manual 10.6.
http://www.softether.org/4-docs/1-manua ... P_Routing)
I guess that routing table setting may be not correct.
What setting did you apply to routing table?
freeiran
i wanted to see this page for see all of the page need to login, i havent any local account.
my client softether ip is 1.1.1.2 located this ip on NIC ( also my NIC has a public IP)
my server virtual interface on layer3 switch on softether is 1.1.1.1 ( now my NIC only has public IP )
now when i connect cascade connection ihave ping from 1.1.1.2 to 1.1.1.1 and 1.1.1.1 to 1.1.1.2
also ihave ping from public ip on client to 1.1.1.1
but i havent ping from public IP on server to 1.1.1.2!!!!!
when i wanted to have bridge between softether server and server NIC because of i have VPS and data center doesnt active pomiscuous for me, i cant have this bridge.
now i want to route a public ip from server to client
please help me about config
regards
regards
The virtual Layer 3 switch don't let communicate to the host OS with the virtual hub.
You should use VPN client to communicate with the virtual hub instead of local-bridge.
freeiran
you put route option on layer3 switch, i wrote route but it doesnt work yet, i thnik may i have problem on routing rule or maybe your route command doesnt work good, that was the reason i need to your help about config, also i need too see the page that you sent me before, it needs special account. maybe it can help me
and in the other hand i should say when i connect cascade, i am connectiong to virtual hub trough vpn, is there any difference to the thing that you said.
also i am using windows route to have communicate beetween layer3 switch and server os , but it doesnt have,
do you think it is so wonderfull.
i am waiting for your guide.
regards
regards
If you want to communicate a remote PC with VPN, you don't need to use virtual L3SW.
Of course, you don't need to configure routing table.
Please try PC-to-PC form VPN network.
http://www.softether.org/4-docs/1-manua ... -to-PC_VPN
freeiran
thanks alot for your reply, but i have a quesion
i have a device beside of my client that i have bridge on that should have a public IP that this public IP is for example should be from the range of softether server to bypass the filterring.
so i cant use pc-to pc technique, because of i have a softether server, and client pc, and a device beside client pc, that i want after i made the bridge , could to route ip address trough vpn to client and after that route to device.
is there any way to i solve that problem for promiscuous when i made bridge, because of i simulate these on 2 computers here and work fine, but i have vps and data center because of security, doesnt enable promiscuous mode for me
i said before i can ping from public IP at client the vpn server IP ( 1.1.1.1 )
but from server public IP i cant ping 1.1.1.2
please help me about that
regards
regards
Do you want to access from device in client side network to the Internet?
If so, it is a good idea is to use the SecureNAT function instead of virtual L3SW.
The device -(local bridge)-> VPN Bridge -----(Internet)----> VPN Server -(SecureNAT)--> Internet
freeiran
thanks alot for your reply again.
it is a good diagram, but i need that softethet do secureNAT on a private special static IP address, now my usual users having secure nat on my server IP address.
i want to get another IP from data center and allocate this IP to this user all of the time. my user have a VOIP gateway that should register to a softswitch , so my user should have a static public IP that is private that can register to softswitch after they open his IP in firewall
also i wanted to know in this mode my client will get an ip ehich is not public, how can route public IP trough NAT and client which takes non-public IP?
do you think it is better that i can make a connection between layer3 switch and VPS?
when you have routing oprion on layer3 switch why it doesnt work correctly?
does it possible?
regards
does it possible?
regards
Virtual L3SW is not NAT router.
If you need NAT with special setting, you should setup a dedicated NAT server on your VPS.
freeiran
i have a question
layer3 doesnt do NAT
layer3 doesnt do Route,
do you think it is really layer3.
i think it is better that named that internal virtual interface.
am i right?
thanks alo for your reply
regards
am i right?
regards
Virtual Layer 3 switch route the packets.
You must specify a virtual L3SW as a gateway to the destination network into routing table of all involved hosts.
(Of course, you can set it as the default gateway.)
In order to communicate with the Internet through a virtual L3SW, all attached networks should be using a global IP address, and upstream router should know the virtual L3SW as a lower router.
freeiran
hi
i did all of that, but it doesnt route.
Configuring IP network is very complex.
Please show your network configuration specific.
