after install 2 softether server in same subnet and enable securenat 2 server start exchange packet and cpu load is 100%
If you disable one of the two servers, one works well
any suggestions ?
like this topic http://www.vpnusers.com/viewtopic.php?f=7&t=1430
2 softether in same subnet
Re: 2 softether in same subnet
Don't you use SecureNAT with local-bridge?
These functions should not be enabled at the same time.
mamaj
thank you
you are fabulous
thank you
you are fabulous
