why softEther using this amazing ram memory !?
hyper
Post by hyper » Thu May 30, 2013 3:04 pm
hi
why softether using 3 gb of my server ram with only 15 online users?
and why cpu usage (2 core 3,2 ghz) is high?
please see the attached image
hyper
Re: why softEther using this amazing ram memory !?
Post by hyper » Sat Jun 01, 2013 8:14 am
up...
dnobori
Post by dnobori » Sun Jun 02, 2013 4:17 am
Perhaps you did wrong configuration, for example, making a loop between physical network and SecureNAT.
Disable SecureNAT.
hyper
Post by hyper » Sun Jun 02, 2013 8:21 am
Thank you very much for your reply
in my vps can't disable secureNat because the mac spoofing is disable and can't use local bridge
in secureNat settings i changed this field:
tcp session timeout: 60
udp session timeout: 60
and in virtual hub extended options, i changed this values to true:
noAddressPollingIPv4
noAddressPollingIPv6
NoIpTable
NoMacAddressLog
ManageOnlyPrivateIp
ManageOnlyLocalUnicastIpv6
YieldAfterStorePacket
NoSpinLockForPacketDelay
NoIpv4PacketLog
NoDhcpPacketLogOutsideHub
DisableHttpParsing
DisableCorrectIpOffloadCheckSum
i doing this changes for Reduce cpu & ram usage but No effect
can this problem for one of this changes?
if yes, what field creating this problem?
Post by cedar » Sun Jun 02, 2013 2:39 pm
I think that something error has occurred in the VPN server.
Please try to find suspicious message in VPN server log.
