hello,all..
I install SoftEther VPN server in my linux server , and my clients (softether vpn client) connected properly..
Now , I want connect to my server via MS-SSTP ( win7 client)
I enable MS-SSTP in my server , and I register my host in vpnazure.net ( myhost.vpnazure.net) and name resolution is ok.
But, I can not connect to myserver via SSTP vpn !!
I don't know what is the problem!
Guess: usually, SSTP client need certification to connect SSTP VPN Server, But i have not any certifaction from vpnazure.net ..
Any suggestion??
why i can not connect to my server??
(sorry,my english language is not very well)
Using MS-SSTP service do not need any certification??
lastchance843
Re: Using MS-SSTP service do not need any certification??
VPN Azure service provides SSL certification for ".vpnazure.net" domain.
What error message are shown when you connect the VPN server?
lastchance843
Hello all,
Special Thanks to Cedar and SoftEther Project
Error no: 0x8007003A : The Specified server can not perform the requested operation
Suddenly, the problem is solved !!
I tiked the PAP (Plain/text Authentication Protocol) and problem is solved,and i could connect from win7 client to my server !!
I don't know whyyyyy we need to PAP in SSTP (secure and encerypted connection) !!!!!!
But there are 2 problems .
Problem1: win7 (32bit) client connected successful but he is disconnecting every 15 second !!!!
and other client , win8 (64bit) connected without problem !! (disconnection not happend)
Problem2: when i create a new user, that user can not connect to my server via MS-SSTP service , if he use softether client program , he can connect to my server , and afterr thatt , he can use MS-SSTP service !!! (one time need to client connect to my server via softether client program) , what's the reason????? is it bug??
Any Suggestion??
(Problem2 is more important for me)
Any Suggestion??
