hi
can i disable data compressing from server ?
because i think this feature is using high cpu and i will disable it from server to any client cannot use it
disable data compressing on server ?
Re: disable data compressing on server ?
There is no setting to disable data compression on VPN server.
If you feel unpleasant it, it is also possible to shut down the session by detecting data compression from the session list.
