how to initialize softether vpn server
howard
Post by howard » Tue Jun 11, 2013 8:42 am
Hi,I have set up the softether server on windows server2008(in campus lan network), and I want to use this server as a proxy server, I can connect to this server outside campus but I can't visit some webs of our school via proxy. So I want to set up the server again, and how to initialize the configuration? Thanks.
360sync
Re: how to initialize softether vpn server
Post by 360sync » Tue Jun 11, 2013 8:57 am
Hi Howard,
Do you mean websites internally for your school, where these are only available on the school LAN and not available externally? Check your name servers, if these are using external dns servers, then internally would not resolve for you. Updating to internal name resolution would help in this scenario.
howard
Post by howard » Tue Jun 18, 2013 1:37 am
Hi,360sync,
Thank you. some websites are only availible on school LAN and not available externally. I installed the softether server on a server of my lab, and I can connect to it with help of softether server(VPN), I want to use it as a proxy server to access the unavailable websites when I am out of school. Can you teach me how to configure?
360sync wrote:
> Hi Howard,
> scenario.
Post by cedar » Tue Jun 18, 2013 3:43 am
You can initialize configuration in "Edit Config" on VPN server manager.
