XP work , Win7 not work, same configuration setting
chemical349
Post by chemical349 » Wed Jun 12, 2013 10:59 am
anyone can shred me some light, i had try to setup ethersoft on two machine,
1. xp
2 win7
both use identical setting, both firewall off & anti virus is the same.
the xp is working but the win7 which i install the ethersoft more then 3 times are identical with the setting on the xp.
but the xp work like a charm and the device i used to connect this win7 install get the below error message.
A Connection could not be established to the PPP server. Try reconnecting.
both router also NAT to port 500 &4500.
hope someone can help me to explain why.
regards,
Re: XP work , Win7 not work, same configuration setting
Post by cedar » Wed Jun 12, 2013 12:46 pm
Did you check server log on you VPN server?
chemical349
Post by chemical349 » Fri Jun 14, 2013 10:35 am
i have not go through the log yet but i have decide to create a virtual centos on this machine to test it
because i try to go through the log but i have no idea what it is about.
may i ask can i post the log here to seek for expertise advise?
so many advertising??
Post by cedar » Fri Jun 14, 2013 1:57 pm
Please read the server logs around the time connected.
About part of it is thought that it does not contain your personal information, you may post it here.
I want to confirm situation.
SoftEther VPN Client don't use PPP or IPsec to connect the VPN server.
What client software are you using?
chemical349
Post by chemical349 » Fri Jun 14, 2013 3:37 pm
thank you very much for your help cedar.
of course i don't mind to post my log here.
i am using my iphone to connect. and i am sure i select L2TP.
i also don't know why the log mention ppp. it is a pop up message on my iphone in that blue square said ppp.
i don't know it also.
below is my log,
i think i have locate the error,
2013-06-14 23:32:27.124 L2TP PPP Session [219.77.172.221:1701]: Acquiring an IP address from the DHCP server failed. To accept a PPP session, you need to have a DHCP server. Make sure that a DHCP server is working normally in the Ethernet segment which the Virtual Hub belongs to. If you do not have a DHCP server, you can use the Virtual DHCP function of the SecureNAT on the Virtual Hub instead.
2013-06-14 23:33:10.141 L2TP PPP Session [219.77.172.221:1701]: The VPN Client sent a packet though an IP address of the VPN Client hasn't been determined.
2013-06-14 23:33:10.141 L2TP PPP Session [219.77.172.221:1701]: A PPP protocol error occurred, or the PPP session was disconnected.
but i am 100% sure my DHCP in the wifi router is enabled, which other machine on my lan is working perfectly.
will this be something related to the setting i did in my softether vpn server while i setup?
IT'S WORKING after i enable the Virtual NAT & Virtual DHCP with SecuarNAT, but the performance, speed to be exact, seems downgrad a lot!
will this be related to the setting i did? i can pm you an access my my machine via a team viewer, if you don't mind and willing to help. or screen capture you my setting?
i am also the one trying to test on installing in centos. but i don't know what install.sh is, can you shred me some more light about how to install softether via install.sh?
million thanks in advance.
Post by cedar » Fri Jun 14, 2013 4:29 pm
Do you enable local-bridge to bridge virtual hub and your LAN?
If so, I guess that you used wireless NIC to bridge.
Most of wireless NICs can't enter promiscuous mode to keep privacy.
Please use wired NIC to bridge.
chemical349
Post by chemical349 » Fri Jun 14, 2013 4:41 pm
oh, you are right. my laptop is using wireless nic.
but was this the reason cause the performance downgrade?
can it b fix? or it has to be a wired lan?
Post by cedar » Fri Jun 14, 2013 11:28 pm
Virtual NAT function is slower than local-bridge.
If you want more performance, please try wired LAN.
chemical349
Post by chemical349 » Sat Jun 15, 2013 1:29 am
million thanks.
chemical349
Post by chemical349 » Sat Jun 15, 2013 4:47 pm
i have a bad news.
after i have added a LAN cable and disable the Wireless Lan card,
i still cannot connect the server and get that DHCP issue.
i will try to remove and reinstall the whole software and it still need to enable the Virtual NAT & Virtual DHCP with SecuarNAT, if i want it to work.
any idea?
thanks.
chemical349
Post by chemical349 » Sun Jun 16, 2013 5:01 am
sorry sir, thanks for your reply but i don't understand what you mean.
can you explain a bit more?
Post by cedar » Sun Jun 16, 2013 3:10 pm
Did you establish a local-bridge from your virtual hub to wired NIC?
Can your NIC be assigned an IP address from any DHCP server?
chemical349
Post by chemical349 » Mon Jun 17, 2013 3:04 am
i have set a fix ip 192.168.1.103/24 set.
may i ask what do u mean establish a local-bridge from virtual hub to wired NIC? shall i do this in my wifi router (dhcp)? or in the softeither server ? or in the win7 control panel?
Post by cedar » Mon Jun 17, 2013 11:21 pm
Local-bridge is a VPN server setting to bridge virtual hub and real network.
http://www.softether.org/4-docs/1-manua ... al_Bridges
