error 85 while connecting Bridge to vpn server
chemical349
Post by chemical349 » Sat Jun 15, 2013 4:44 am
i have encounter an error while i try to connect the bridge with the vpn server, it is error 85 :unable to trust the certificate...... and it's setting is in vpn setting .(which i cannot find this)
i am playing with the vpn to vpn setting.
can someone share with me some of there past experience?
tks in advance.
Re: error 85 while connecting Bridge to vpn server
Post by cedar » Sat Jun 15, 2013 3:19 pm
You should set correct server certificate or trusted CA in connection setting.
http://www.softether.org/4-docs/1-manua ... rification
chemical349
Post by chemical349 » Sat Jun 15, 2013 5:13 pm
tks, i shall try.
