how to set up ipv6 support on softether server(vps has both ipv4 and ipv6)?
one, vpn client is using ipv6 to visit softehter server to get both ipv4 and ipv6 passing through.
other, vpn client is using ipv4 to visit softehter server to get both ipv4 and ipv6 passing through.
http://linc01n.github.io/blog/2013/05/1 ... al-bridge/
Now I can set up an ipv4 softether server from the post above.
but how to set up ipv6 support?
how to set up ipv6 support on softether server?
copperfiled
Re: how to set up ipv6 support on softether server?
There is no special setting to enable IPv6 support.
If the VPN server have a valid global IPv6 address and routing, you can access to the VPN server via IPv6.
copperfiled
no, I tried, it failed,
it needs to set ip6tables dhcp6 and etc..
but I have no idea about ipv6.
I think that the problem don't depend to VPN software.
Please try to contact your network administrator.
vitaliksys
can you help with setup then ? please provide a comprehensive tutorial or contact me via skype - zosea.frosea
