hi
when users connected with vpn over dns on server, if a user select "adjustments of routing table" on connection settings, and connect to server, all of users in dns mode will disconnect !! and no body can connect to vpn over dns for a period time
can disable this option? or resolve this bug in new version?
1 bug on dns mode
kh_tsang
Re: 1 bug on dns mode
I think it is better to use ICMP instead of DNS packet.
hyper
up...
please fix this bug
please fix this bug
hyper
how can i disable "no adjustments of routing table" settings from server?
i want no one can use this option!!
mabaega
hi... could you tell me how to setup VPN over ICMP?
http://www.vpnusers.com/viewtopic.php?f=7&t=2447
Thank's
Thank's
This is not a bug.
Usually, the VPN client add a routing table entry to maintain the VPN connection path when VPN connection.
If you disable this feature, the path of VPN connection may be lost by changing default gateway.
If there is likely to change the default gateway, please do not use this option.
hyper
thank you so much for your reply
how can i disable this feature on the server?
