How to Export Configuration
inten
Re: How to Export Configuration
Post by inten » Wed Oct 30, 2013 9:53 am
Save config and then Import and Apply.
kh_tsang
Post by kh_tsang » Wed Oct 30, 2013 11:47 am
If same CPU type, move the vpnserver directory to your new server.
If differnet CPU type, move the vpnserver directory to your new server and download the correct build and replace files in the directory if there is file conflicts.
