As stated in the documentation, you don't need to install the SoftEther VPN Client on Windows 8 client machine. I did that at first but I wasn't able to connect my Windows 8 machine. I even tried changing the VPN connection properties manually in the "Type of VPN" and set it to "SSTP (Secure Socket Tunneling Protocol)" but I still cannot connect. Disabled my ANTIVIRUS but it's still the same.
Installed the SoftEther VPN Client and immediately I got connected without much effort. Hope this issue can be addressed by the authors as stated in the SoftEther VPN documentation. Any other troubleshooting suggestions on this issue?
Clientless Windows 8 machine not connecting
Re: Clientless Windows 8 machine not connecting
Have you configured SoftEther server in some way?
Be aware that for SSTP you need to have a valid SSL certificate on the server side which also on client side can be validated against the CA-root authority or, as an alternative, is installed as a self signed certificate on the client.
I did not try it, but in vpn server you can export the server certificate ...
L2TP is a much more easier to use protocol, it needs no certificates.
