If i set an expiry date for a user in SoftEther, either by the Management Console or the terminal command "UserExpiresSet", the users' expiry date never gets set correctly.
Doing it through the Management Console doesn't save the date correctly, it sets the start date and expiry date to the same dates.
Doing it through the terminal does the same.
So whenever there's an expiry date for a user that user can't use the VPN, as the VPN always thinks the user is expired due to the expiry date being the same as the users' creation date
Any one had this issue?
UserExpiresSet not setting expiry
raafat
Re: UserExpiresSet not setting expiry
May you post some screen shots for the issue you face ?
nickmccomb
VPN expiry date doesn't save on either date fields. When i change the dates and press OK and go back into these settings they revert back.
nickmccomb
Anyone know why this is happening?
It looks that your Date-picker component doesn't work correctly.
I attach my screenshot.
