Windows Phone
kovacsadam07
Windows Phone
Is there any way to configure Windows Phone to connect a SoftEther VPN Server? I enabled everything in the router, enabled L2TP on VPN Server but it does not work. I tried with Automatic on my phone as well as all other options.
I can connect from my Windows PC with SoftEther Client.
raafat
Re: Windows Phone
What is the version of Windows phone that you use ?
kovacsadam07
Re: Windows Phone
The newest Windows 10 Mobile (L640)
Re: Windows Phone
Did you configure port forwarding UDP/4500 and UDP/500 to the VPN Server?
Did you try Android or iOS to connect the server?
kovacsadam07
Re: Windows Phone
The port forwarding solved the problem, thank you! I didn't find this information. Maybe it can be on one of these sites:
https://www.softether.org/4-docs/2-howt ... ac_Laptops
https://www.softether.org/4-docs/2-howt ... VPN_to_LAN
Oh, I just found this...:
https://www.softether.org/4-docs/2-howt ... VPN_Server
Maybe more link would be helpfull :D
GKL1520
Re: Windows Phone
When you said port forwarding solved the problem, does that mean you are now successfully able to use your windows phone to remotely access your home network ?
If so, is the port forwarding used in a way that is secure as I have heard that port forwarding is usually not secure ?
Should your solution work with our phones, router, and ip cam listed below ?
Windows Phones: Nokia Lumia 1520 and Microsoft Lumia 640 LTE (both running Windows mobile 8.1 with vpn client "L2TP over IPsec")
VPN Router: ASUS RT-ACRH13
https://www.asus.com/us/Networking/RT-A ... fications/
IP Camera: HIKVISION DS-2CD2342WD-I
http://www.hikvision.com/us/Products_1_10508_i7593.html
Thanks !
Gary
Thanks !
Gary
GKL1520
Re: Windows Phone
I'm having a similar problem, where do you get the specific info you need to configure port forwarding UDP/4500 and UDP/500 to the VPN Server ?
(I'm new at this stuff)
Thanks !
Thanks !
Re: Windows Phone
It's router setting.
Your acccess router may have NAT function.
Port-forwarding allows the router to redirect specific traffic into your PC.
Please read the router manual for detail operation.
GKL1520
Re: Windows Phone
> PC.
Thanks, your reply is appreciated !
My problem is the router manual seems to assume I know what values to input, but I am new at this and it's a guessing game, the values I tried obviously were not right somehow.
The port forwarding section has the following fields to fill in and I'm guessing what to put in each one and the only one I am sure of is the Protocol being UDP. I'm not sure if the "Local IP" means the IP of my computer or the IP of the windows phone I am trying to connect with.
Service name:
Source target:
Port range:
Local IP:
Local port:
Protocol:
> PC.
Service name:
Source target:
Port range:
Local IP:
Local port:
Protocol:
kovacsadam07
Re: Windows Phone
When you forward a port you have to specify the external port (this is the port of your router on the internet side) a local ip and a local port (this is the computer and its port where the router should forward the data coming from outside (internet) ). Beside them you should add a name for indentify for yourself. Protocol is usually TCP/UDP.
In your case I have no idea what source target is. Port range may be your external port, local ip and address is the same I wrote above.
GKL1520
Re: Windows Phone
Thanks for the reply and idea, I found what I had wrong from an ip camera forum, I had some settings wrong and/or omitted both in Softether and my router settings, and my windows firewall was blocking the connection too, got it working now. And I found out the port I had to forward was the one that comes up for ipv4 on the computer hardwired to my router.
The OpenVPN would have been an easy solution, but Windows phones don't have an OpenVPN client, but an L2TP/IPsec client, hence the need for using the free open source Softether VPN server software on my computer.
GKL1520
Re: Windows Phone
AmySoto wrote:
> Thanks for the information, it helps me a lot
Great, I am glad, I know this stuff can be frustrating to figure out sometimes, I had to do weeks of research and asking questions and if this info can save anyone else some time figuring it out that is good !
Any further help needed just ask, if I don't know then likely some of the more experienced members can be of help.
