http://www.softether.org/1-features
Features
    Easy to establish both remote-access and site-to-site VPN.
    SSL-VPN Tunneling on HTTPS to pass through NATs and firewalls.
Revolutionary VPN over ICMP and VPN over DNS features.
    Resistance to highly-restricted firewall.
There are no Manual for setup [b]VPN over ICMP[/b]
How to setup VPN over ICMP?
and how to setup client to connect VPN via ICMP?
[attachment=0]0-09-ss1.6.jpg[/attachment]
Thank's
						VPN over ICMP
				mabaega
VPN over ICMP
				Shaahinm
Re: VPN over ICMP
Hi
Go to Encryption and network, VPN over ICMP/DNS, check one of them. Then delete the port from listener list (you might need to open it in firewall).
