SoftEther VPN RPM for CentOS 6
Locked
thepoch
Post by thepoch » Tue Jan 28, 2014 8:30 am
<sorry no longer available>
parkycai
Re: SoftEther VPN RPM for CentOS 6
Post by parkycai » Wed Jan 29, 2014 1:39 am
THX! can it automatically start up on system boot?
thepoch
Post by thepoch » Wed Jan 29, 2014 1:45 am
thepoch
Post by thepoch » Wed Jan 29, 2014 5:34 am
thepoch
Post by thepoch » Mon Mar 03, 2014 9:13 am
andy_hay911
Post by andy_hay911 » Wed Apr 02, 2014 11:18 am
thepoch wrote:
> Hi guys,
> I don't know if it's appropriate here (if not, just delete my post I
> guess?), but I made SoftEther VPN RPMs for CentOS 6. I've put it up here
> (hopefully my bandwidth can handle it):
> http://projects.thepoch.com/softethervpn/
> and the SPEC file (plus script to change the makefiles) are available here,
> if you want to build the RPM yourself to verify I didn't change anything
> with the code:
> https://github.com/thepoch/SoftEtherVPN-RPM
> But basically, I just compiled the sources as is, only creating an RPM for
> easy management, plus added the initscript. It seems to work on my VM, with
> a Windows desktop accessing and configuring the server.
> Hopefully it works and is helpful.
> Dex
andy_hay911
Post by andy_hay911 » Wed Apr 02, 2014 12:41 pm
Do you have RPM file for CENTOS 5.1 32bit ?
thepoch
Post by thepoch » Thu Jun 05, 2014 9:37 am
thepoch
Post by thepoch » Thu Jun 05, 2014 9:38 am
<sorry. no longer available>
bomb3rman
Post by bomb3rman » Thu Jun 19, 2014 8:40 am
how to install that one centos?
can you give me the commands?
thepoch
Post by thepoch » Thu Jun 19, 2014 11:01 am
thepoch
Post by thepoch » Thu Jun 19, 2014 11:03 am
thepoch
Post by thepoch » Tue Jul 15, 2014 8:21 am
thepoch
Post by thepoch » Fri Oct 24, 2014 10:35 am
<sorry. no longer available.>
quattrolinux
Post by quattrolinux » Sat Jan 09, 2016 5:18 am
thepoch wrote:
> http://projects.thepoch.com/softethervp ... x86_64.rpm
Looks like server is no longer exist.
Locked
