I read that SoftEther VPN Server can be used behind a firewall without having to set up port forwarding.  It is supposed to use something called UDP Hole Punching.  I could not get it to work.  Do I have to do something in the configuration to turn this on or is it on by default?
I also tested it with VPN-Azure feature and it works but this is only for Windows (SSTP protocol) and I am trying to use SoftEther for my Android phone which only supports L2TP/IPSec.
I am behind two firewalls, one of which I have no control over.  The main firewall that connects to the Internet is managed by my apartment complex and I do not have any access to.  It has a direct connection to the Internet and a LAN IP address 192.168.1.254.  Then another firewall/router which is the one in my house that I do control with an IP address of 192.168.1.60 on the WAN side and my own subnet 192.168.0.x that it routes for.
Thank you.
Picture of my network is attached: http://i.imgur.com/cLN0hUg.png
I am running SoftEther on my PC inside my LAN at IP address 192.168.0.5 (not shown in the picture).
						VPN Server behind firewall, no port forwarding
				alexthered88
				alexthered88
Re: VPN Server behind firewall, no port forwarding
With the softether.net DDNS IP, neither L2TP/IPsec nor SSTP works.  Nothing in the logs so I believe no traffic is getting past the firewalls to the VPN Server.
With the vpnazure.net DDNS IP, L2TP/IPsec does not work, but SSTP does (have to turn on SecureNAT). Why doesn't vpnazure.net support L2TP/IPsec as it would solve the Android/iOS compatibility issue?
