Hi, All:
    I had created a Virtual hub with SecureNAT / DHCP are enable.
And I also create a localbridge with my lan side.   When vpnclient connected with server.  server seems always do forwarding  first.  So my vpn client will alwasy get
the IP from lan side IP.  But I just want to let client has ip 192.168.30.20  from vpnserver.
Is there any control flag that I can do this ? control dhcp pkts can be send to vpnserver first instead of forward to lan side.
						external / internal DHCP server question.
				dnobori
Re: external / internal DHCP server question.
You can filter incoming DHCP packets from the physical network by using Access Control List.
