Protocol error occurred, blocked ports ?
kamil445
Post by kamil445 » Sat Apr 12, 2014 2:28 pm
I have a message in SoftEther VPN Server: "Protocol error occurred" in "Global IPv4 Address"
How to fix it ?
If i connect to another VPN, working fine. (WTF)
I use DMZ on my local IP address. (All ports opened)
Reserved Ports via other servers (80,27000-27020,6969,3306)
Reserved porta to VPN server : 443,992,1194,5555 (default ports)
When my VPN server be visible in vpngate.net ?
Re: Protocol error occurred, blocked ports ?
Post by cedar » Tue Apr 15, 2014 6:54 am
Something may block the connection to DDNS registration server.
By the way, please don't open the DDNS key to a third party.
Someone can mimic your VPN server.
colseven
Post by colseven » Sun Jun 15, 2014 5:48 pm
I'm having the same issue. Dedicated the 4 default ports. UPnP enabled (VPNGate module uses this).
IPv6 not available. IPv4 in use.
Randomly I can see my external IP address appear and disappear. However I can not customize the DDNS Hostname as it returns an error.
colseven
Post by colseven » Mon Jun 16, 2014 4:51 pm
Bump. Any ideas?
Post by thisjun » Thu Oct 23, 2014 7:54 am
Please configure proxy setting if you need.
kamil445
Post by kamil445 » Fri Nov 07, 2014 8:36 pm
if i use proxy i have this
"The connection to the Dynamic DNS server has been disconnected."
Any solution ?
kamil445
Post by kamil445 » Sat Nov 08, 2014 12:26 pm
Connect to VPN via SoftEther VPN Client, Open VPN, L2TP and MS-SSTP working fine,
Ports 443,1194,5555 and more is opened. DMZ is enabled.
My IP is reachable from the Inetrnet.
If i delete server config and create new, All works fine i can see my external IP in Global IPv4, and i can change DDNS.
Now, if i enabled "VPN Gate Relay Service", Global IPv4 has an error occured (see - Protocol error occured).
TCP/IP is used to connect to the DDNS, on port ?
Post by thisjun » Tue Nov 18, 2014 8:45 am
I guess your ISP restrict VPN Gate. maybe....
kamil445
Post by kamil445 » Tue Nov 18, 2014 2:33 pm
Okey i have idea.
My router is.. shit!....
My actually router TP-LINK WR740N, with this router i have "Protocol error occured".
If i use my old router TP-LINK 340G, all works!!! (with default settings)
I tried to configure WR7540N, bu i dont have no idea how to "FIX" that.. i tried use all settings... and don't work :(
My connection is via PPPoE protocol.
Anyone know how to set up the settings in WR740N ????
kamil445
Post by kamil445 » Thu Feb 19, 2015 9:32 am
For me.. I have fix:
In router disable UPnP (Universal Plug and Play), restart router and PC.
NOW! works perfectly! no problem with "Protocol Error Occured" in Global IPv4 Address ! :D
