So I used to use a single standalone server VPN. I have now switched to using a cluster to take advantage of more servers and IP's. However, now that I have switched, I can connect to the cluster but my traffic is not sent through VPN and my IP does not changed like it used to.
-There are 2 servers in the cluster. (1 controller, 1 member)
-They both run Ubuntu 12.10 x64. Both have Softether v2.00.
-When I connect, my Virtual Network Adapter looks for a DHCP assigned IP from the VPN. However it never confirms that it got one like it used to with the standalone VPN. (I'm not sure if you have to create a bridge to a LAN with a cluster.)
-I check my IP and it does not change when connected to the VPN cluster.
-I use Windows Softether VPN manager to manage the servers. However, I can SSH to them if needed.
-I use one static Hub for the cluster.
						Traffic Not Going Through VPN Cluster
Re: Traffic Not Going Through VPN Cluster
Can you show these information ? http://www.vpnusers.com/viewtopic.php?f=7&t=2790
				theodisbutler
You'll need to install dnsmasq or other DHCP server and create local bridge.
