Openvpn SSL error
mesa57
Openvpn SSL error
Post by mesa57 » Sat Jun 21, 2014 7:44 am
Some strange behaviour. If I import the openvpn settings om android it works perfectly. Until after a few days I cannot connect to my server anymore : Polar SSL error.
In the Openvpn log : error verifying CA certificate.
Strange because initialy it did work.
What I do see is that the CN=name differs from my server URL. But openvpn does not tell if that is the problem.
I am using latest version of Softether server : softether-vpnserver-v4.09-9451-beta-2014.06.09-linux-arm_eabi-32bit.tar.gz (5.01 MB)
Anyone a clue ?
mesa57
Re: Openvpn SSL error
Post by mesa57 » Tue Jun 24, 2014 7:41 am
*bump* Nobody ?
Post by cedar » Tue Jun 24, 2014 1:43 pm
Please try to re-create the server certificate.
Especially if you update the server from an older version.
mesa57
Post by mesa57 » Tue Jun 24, 2014 1:52 pm
Thanks for you're reply :)
I regenerated the certificates about 10 times now.
Everytime I import the .ovpn profile in openvpn connect it works.
For one day and then it says the embedded certificate is not valid.
dnobori
Post by dnobori » Wed Jun 25, 2014 3:24 pm
Is your SoftEther VPN Server running VPN Gate relay service?
mesa57
Post by mesa57 » Wed Jun 25, 2014 6:07 pm
No, it is running as a normal server (on a raspberry PI).
mesa57
Post by mesa57 » Sat Jul 26, 2014 6:58 am
Finally a solution (I hope). I have changed the dns adres (xxxxxx.softether.net) in the generated .ovpn file to the IP adres of the server.
Until now openvpn (connect) seems to connect and does not run into the Polar SSL error.
I will keep on testing for the comming days.
If somebody has an explanation for this behaviour ?
mesa57
Post by mesa57 » Sat Aug 09, 2014 7:31 am
That was indeed the solution. It appears that the softether DNS server sometimes switches to an other IP address if I use xxxxxxx.softether.net
If I restart the server the DNS entry is apparently corrected, but after a while it changes to an other IP.
