This guide worked for me in Ubuntu
https://www.digitalocean.com/community/ ... -softether
I think you need to set only SecureNat without bridge, because if you set bridge you'll have to set iptables forwarding manually.
"There are two ways of connecting your hubs to the server network: using a Local Bridge connection or using the SecureNAT function.
You can use each one separately, but using these two together will cause problems."
HowTo get Internet Access over VPN - Linux
ziphead
