most vpn server were blocked in china
lqm11
Post by lqm11 » Sun Oct 15, 2017 1:05 am
including japan,south korea ,all their server were blocked by gfw in china.
Please work out some methods to solve these problems and make softether vpn vailable in china.
thank you.
whitefish
Re: most vpn server were blocked in china
Post by whitefish » Wed Oct 18, 2017 5:59 am
Are you talking about the VPNGate servers? Most of these servers don't work well anyway. Or did you set up your own server?
My Korean SoftEther server still runs great.
Which port are you connecting to and are you using UDP? I would stick to Port 443 TCP only since it is SSL traffic that should be undetectable by the GFW.
SoftEther for the time being seems to be one of the few remaining protocols that passes the GFW without disruption.
glunbk
Post by glunbk » Thu Oct 19, 2017 2:04 am
In China, the SoftEther VPN Client has been unable to use it as if the UDP TCP protocol included many ports that were shielded by telecommunications
whitefish
Post by whitefish » Thu Oct 19, 2017 2:12 am
You can set the client to use any TCP port. I would recommend port 443 which is commonly used for https. You can also use port 80 which is the common http port but some servers may have this port blocked. You will need to use TCP. Using UDP acceleration is an option. So unless the SoftEther server IP address is blocked in theory you should be good to go.
whitefish
Post by whitefish » Thu Oct 19, 2017 12:54 pm
My SoftEther server was blocked on 3 different ports that I was using. Here is what is really weird:
1) The blockage is only on China Telecom (I tested on 2 residential connections) but it is not blocked on another China Telecom account (which was also signed up as a personal account but is in an area 3 km from my home).
2) Another port is not blocked so the blockage is port specific.
3) It is not blocked on China Mobile nor China Unicom.
So here you have it: the blockage is not by the "GFW" but by the specific ISP and in fact regional. Choosing another port solves the issue.
You may recall that there was a news article stating that the government is forcing ISPs to block VPNs so the block is ISP specific. What is also strange is that I have practically never connected to my VPN server via the China Telecom residential connections.
xodc
Post by xodc » Wed Nov 01, 2017 8:42 am
Can you show me where the UDP acceleration option can be turned on or off?
lqm11
Post by lqm11 » Wed Jan 31, 2018 12:56 am
the condition is worse now. almost all vpn servers are blocked in china .Please work out some ways to make vpn work in china. thank you.
lqm11
Post by lqm11 » Sun Jun 03, 2018 7:42 am
it is used well ,but i am still thinking,why this free vpn gate became useless in china. It is used well beore, but now every vpn server is blocked in
china. How can i unblock these servers? The owner of this site must work out some way ot make vpn gate become useful in china,I hope it can be done very soon. Thank you for your valuable work, but its price is a little high for me, i may try ,but soon i iwll give it up ,sorry for that.
lqm11
Post by lqm11 » Thu Jun 07, 2018 9:10 am
please make vpn gate work in china as soon as possible ,i apply for it ,site owners. thank you.
lqm11
Post by lqm11 » Wed Jun 13, 2018 9:55 pm
eiko wrote:
> did you try this?
> https://aicochow.github.io/vpn/
i am refused by the server. It isnot enough ,it is not seven day limit. Please fix it .thank you.
lqm11
Post by lqm11 » Mon Jun 18, 2018 6:05 am
eiko wrote:
> did you try this?
i am refulsed by the server . Your vpn server cannot be connected.
Please make it useable.
lqm11
Post by lqm11 » Fri Dec 14, 2018 8:06 am
who can fix this problem? I cannot use vpngate in china. Please fix this problem and make vpngate useful in china. Thank you.
lqm11
Post by lqm11 » Sat Feb 23, 2019 6:49 am
please help to make vpn servers in china return to work. thank you.
sky59
Post by sky59 » Wed May 01, 2019 4:46 am
@lqm11,
There is no problem with vpn SE at all. I just went through some problems recently and realized SE can not be matched by anything
else! It definitelly works also in China.
I have "discovered" many routers can block vpn protocols, like Linksys. For instance openvpn, ipsec and others but they can not block
https as they would block internet - and it is the reason why they are there. If they block https protocol and port 443 you can smashed them out of the window. So if Linksys and other manufacturers and ISP providers want to get your money they MUST provide transfering https and port 443.
And here miracle starts: softether is the only vpn that has got "ethernet over https".
I was figthing with tablet and openvpn apk not connecting to se server, but from other se bridge i could!
Reason is simple: connection from softether to softether on port 443 must work everywhere. If not stop paying ISP because you have effectively no internet!
Now i am fighting with cross compilation for android linux.
I already implemented se into router A5V11, orange pi zero, ubuntu. I use it for connecting siemens plc all around the world and no
single instance occured it would not work.!
Remember: only Softether-softether is working. Using any other apk does not work as no other vpn is using https!
