Hi All,
Firstly let me say this is a fantastic project and the documentation is also very good and has helped me learn a lot about networking topics. I have a question that is probably something very quick to answer.
I have set up server on a Pi at home and local bridged to home LAN using separate network adapter as mentioned in local bridges.
I set up bridge on another Pi away from home and cascade connect to home Pi server. I have local bridge to eth0 (again this is dedicated to local bridge and not used for Pi itself).
If I plug another computer into remote Pi eth0 it gets IP address from my home LAN perfect. The Lan to Lan connection is working fine.
What I want to know is how to make the remote Pi itself able to access home network. Do I also need to run VPN client on the remote Pi, or how else to be able to access home LAN from remote Pi itself ?
In effect I want a route from remote Pi to 192.168.0.0/24 that goes via the Virtual Hub on the remote Pi
Can the bridge be a client as well
regfixit
Re: Can the bridge be a client as well
I've managed to solve this. Not sure if it's the best way but this is what I did:
On the VPN bridge I added another local bridge to a new tap device called soft. This created a new network device called tap_soft on the remote pi. However, it had no IP address.
I then tried to add entry in /etc/network/interfaces like:
iface tap_soft inet dhcp
and then did ifup tap_soft. THis didn't really work as tap_soft got an ip address in 92.0.0.0 sub net so it didn't "see" the DHCP server on my home LAN.
I then tried instead the following:
allow-hotplug tap_soft
iface tap_soft inet manual
pre-up ifconfig tap_soft up 192.168.0.40
post-down ifconfig tap_soft down
This then worked and gave a fixed IP on the home LAN to the remote Pi. I am not sure if the hotplug part is relevant or not, but I added that because I wanted the assignment to happen as soon as vpnbridge starts up and creates the tap.
dajhorn
This is a good solution. The allow-hotplug line is indeed required because SoftEther tap interfaces come online after physical interfaces are plumbed by the init stack.
Nemesiz
This is the only way to 'see' the network from vpn server or vpn bridge.
regfixit
Thank you both for your replies !
