You will need to redirect the traffic for certain programs/services to do so. In the very least you need understanding of networking.
Using VPN, L2TP, SSTP, etc usually redefines the gateway in which the computer is meant to direct their packets to. Think of how when you are travelling on the road and when you use VPN for instance the road becomes like a fork but you are forced to choose a road that you did not wish to travel on. To travel on the right road could be as simple as in networking terms to not use the VPN gateway IP address, however that leaves you with manually setting programs for instance to choose what goes where or otherwise they would be using your own connection and not the volunteer host's connection.
I am unsure of any programs that could do such things easily however.
Using VPN Gate Public Servers for TeamSpeak3
BoredAus
