I'm an Ubuntu user and I need to connect to a Softether VPN Server.
The Server uses L2TP/IPSec.
It requires Username/Password (taken from an Active Directory) and a Pre Shared Key.
All tutorials were prepared to Windows Users.
I have no windows PCs at home so I managed to install softheter's ubunut package from PPA.
$ sudo add-apt-repository ppa:dajhorn/softether
$ uname -a
Linux berilio 3.13.0-45-generic #74-Ubuntu SMP Tue Jan 13 19:36:28 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
VPN Client>version
VersionGet command - Get Version Information of VPN Client Service
Item |Value
Product Name |SoftEther VPN Client
Version Information|Version 4.08 Build 9449 (English)
Build Information |Compiled 2014/06/08 14:08:09 by yagi at pc25
Process ID |0
OS Type |Linux
I configured the vpnclient creating a Nic and account.
I could not find a way to input the Pre Shared Key while creating the connection. Also I cannot find a command to do that.
I started dhclient on the new interface.
It looked like could connect to the Softether's VPN Server.
I checked with the server admin and he can see my connection.
I can ping to the VPN gw and also I can ping to other connected clients.
I added the routes needed to access the networks behind the VPN, but cannot go beyond VPN gw.
My questions are:
1) Is it possible to my cilent to connect to the vpn even when I have not set the PSK?
2) Not having the PSK set could be the reason why I'm not able to pass through VPN gw?
3) How can I set the PSK using vpncmd only? I have no windows host to run the Client Manager UI.
Set Pre Shared Key (PSK) with vpncmd on Ubuntu
mhdion
qupfer
Re: Set Pre Shared Key (PSK) with vpncmd on Ubuntu
You have a thinking error ;)
vpncmd is the configuration-tool for the SoftEther Client, which is only a Client for SoftEthers own VPN-Protocol (Ethernet over https). It doesn't use a PreShared key, so you can't set one. If you want to use IPsec, you need a IPsec Client.
But you can use the SofEther-VPN Protocoll instead of IPsec.
The commands should be approximated:
sudo vpnclient start
sudo vpncmd /CLIENT
NicCreate (name vpn)
AccountCreate
AccountSetPassword
AccountConnect
Exit
dhcpdc vpn_vpn
sudo vpncmd /CLIENT
AccountCreate
AccountSetPassword
AccountConnect
Exit
dhcpdc vpn_vpn
mhdion
Re: Set Pre Shared Key (PSK) with vpncmd on Ubuntu (SOLVED)
Thanks for your response.
Now I realized that I was talking about different thimgs.
sshpanel
Maybe this is very late haha, but it's actually possible to change the IPSec PSK using vpncmd only. In fact, it's only 1 line of command.
if the IPSec has been already enabled, you can run command below.
vpncmd host:port /SERVER /PASSWORD:your-server-password /HUB:YOUR-HUB-NAME /CMD:IPSecEnable /PSK:your-desired-psk
