nat test
NAT type: UdpBlocked
How do I set it?
SSTP udp is invalid
Re: SSTP udp is invalid
That is not a problem of SSTP, it's a server side NAT problem.
he852100
no ,This is the SSTP problem.Or the problem of SoftEther VPN .There is no problem on the server .
The server NAT type is Full Cone NAT,No problem with L2TP use
he852100
Or is there a problem with my settings? So, please teach
SSTP and L2TP are based on PPP. So these protocols are processed similarly on VPN server.
Did you configure using default gateway on VPN on SSTP client?
