Hi everyone,
i want that the VPN is using my Proxy. So every WEB Request would be tunneld through the proxy.
Can SoftEther VPN do that or is there a easy way for that?
Best Regards
Mr. Schoko
//EDIT
I want to build a VPN Service for my own mobile usage.
Security through VPN connection and my own Web-Filter by Squid Proxy to get rid of Tracking-Software+Cookies and all the bad stuff we have on the Internet.
Proxy after VPN Connection
Re: Proxy after VPN Connection
You can define a virtual hub which have dummy default gateway.
You can place a proxy on the hub to make gateway.
Mobile devices on the hub should be unable to connect to the Internet without the proxy.
But if the mobile device detect the dummy gateway, the device may ignore the default gateway and use mobile internet access.
