Is it possible to change the listening port on VPN server ?
kh_tsang
Re: Is it possible to change the listening port on VPN serve
Post by kh_tsang » Tue Mar 31, 2015 8:54 am
You can add or remove listening ports with the vpn server manager. However, when you change the listening ports, you also need to change the port configured on your vpn server manager.
