Hello!
I'm trying to create a server, but even following the tutorial, I can not create :( .. how should I do?
The antivirus is disabled and windows firewall is enabled. I'm using Windows 7 32-bit, and I also have another computer with Windows 8 64-bit, which also failed to create the server.
Please help mee (sorry for my english)
Problems when trying to create server
Petrol
Re: Problems when trying to create server
We need more information to help you.
What is the error message you get when the installation fails?
Are you installing the software as an administrator?
cnbrkr
Everything went well with the installation. Yes, I installed as administrator.
Why did you determine you fail to create the VPN server?
