I can connect to my Softether vpn server using Remote Desktop with Network Level Authentication on the external interface but I can not connect if I am doing it from the internal side.
I have tried to connect to both the public ip (external side) and the private secure-nat assigned (internal side).
Anyone have any idea what the problem could be?
Basically, what I am trying to do is to remote desktop to/from a bridge server to/from the vpn server.
Re: Remote Desktop with Network Level Authentication
Please show ipconfig result.
Did you create localbridge?
Did you use virtual NAT of SoftEther function?
Config as shown in attached image.
Did you configure the routing table?
