Hi All,
I have setup an softether standalone VPN server. I have setup another standalone server with same hub names ,user names and passwords as previous server. I have added both the IPs in DNS round robin. From client, I am connecting to xyz.com (both the IP's pointing to xyx.com). Client initiating the connection for few seconds and disconnects and again connects then discommects.
Can any one help me, how to add fail over or load balancing with standalone vpn servers.
Thanks,
Sathi
The failover service implementation with standalone servers
Re: The failover service implementation with standalone serv
What error code is shown?
Did you check logs?
I think the problem is not related to DNS round robin.
Did you check logs?
@thisjun thanks for the reply. Will check.
Thank you
Thank you
