SoftEther VPN Critical 'Port Fail' Vulnerability?
Petrol
Re: SoftEther VPN Critical 'Port Fail' Vulnerability?
I'm also curious about it.
kh_tsang
I think it can be solved by using different IP for the VPN Server and the NAT address, or even assign public IP directly to a VPN client. Is it true?
This vulnerability is not a problem with VPN itself.
It's caused by the NAT behavior.
Some anonymizing services allow the user to redirect incoming connection to the user on NAT.
"Port Fail" uses this to determine the victim's IP address.
SoftEther VPN itself don't provide port forwarding function in SecureNAT.
But an anonymizing service using SoftEther VPN can use such NAT system.
(In addition, VPNGate does not perform the port forwarding. It's safe from this problem.)
