VPN Gate server CPU usage.
myzhujiang
Re: VPN Gate server CPU usage.
把客户行为限制.
technomancer
The issue kicks in at about 20Mbps connection usage, and keeps going, when it hit high level of I/O the cpu usage gets too high.
I Don´t know what is going on...
dnobori
Are you using Wi-Fi?
technomancer
No, each one of my servers are connected with 1Gbit link.
Link to img> http://i.imgur.com/b6L4j2N.jpg
Here is one printscreen showing 23% server usage, but only using 15Mbps of the line.
Processor is Intel Xeon E-5
dnobori
Could you check the status of SecureNAT on the VPNGATE Virtual Hub?
If the "Kernel-mode NAT" is running, it is OK. However if the Kernel-mode NAT is not working, there must be something problems.
