vpncmd on linux
Petrol
vpncmd on linux
Post by Petrol » Fri Dec 18, 2015 3:34 pm
I'm trying to import a Configuration file with vpncmd on a computer running linux. I have no problem to connect to the client, just with the AccountImport Command
the command looks like this :
AccountImport /home/path/to/file
My problem is that vpncmd detects the first / of the path as a command parameter (e.g /HELP) and fails to perform the command.
Anyone knows how to solve this?
Thanks
qupfer
Re: vpncmd on linux
Post by qupfer » Sat Dec 19, 2015 9:17 am
did you try to set your path in quotation marks ("")?
Petrol
Re: vpncmd on linux
Post by Petrol » Sat Dec 19, 2015 5:49 pm
Yes,I tried simple quotes ( ' ' ), doubles quotes ( " " ). I also tried to espace the first slash with a backslash but no result
Re: vpncmd on linux
Post by cedar » Thu Jan 07, 2016 8:15 am
Please try to append additional "/" before the path.
AccountImport //home/path/to/file
Also vpncmd can use "\" as path separator.
AccountImport \home\path\to\file
