I have the SoftEther VPN Server running at home, and I connect to it with the SoftEther VPN Client at work.
I am able to access everything I need at the remote site while conected, but I am unable to ping hostnames on my local network (at work) while connected...
is there a way to correct this?
Connection..
Re: Connection..
Don't you use same network address in local and remote networks?
Please change network address of home LAN.
tblaine27
Re: Connection..
home network is 192.168.1.x
work network is 10.18.x.x
Gulaholic
Re: Connection..
Hi, I'm experiencing the same issue.
Will watch this thread.
Re: Connection..
Because the default gateway switch, you may not access the network behind the router.
Please try to set 1000 into interface metric value of virtual network adapter.
tblaine27
Re: Connection..
PERFECT! This took care of my problem. Thank you very much!
if anyone doesn't know where this setting is:
start, run, ncpa.cpl, right click your VPN conection, properties, select internet protocol, properties, advanced, set metric value.
> the router.
> adapter.
> the router.
> adapter.
