iran govermnet ...
gholam
iran govermnet ...
Post by gholam » Tue Apr 02, 2013 8:43 pm
here in IRAN we have empressed from goverment and all defualt VPN ports had blocked,
your project help us to connect via 5555 port ,
but in IOS device and other handy devices like andoird how it work ?
in macosX and windows your application work like a charm but what about IOS and andorid ?
could you please help us and give a solution for us in IRAN :(
Re: iran govermnet ...
Post by cedar » Wed Apr 03, 2013 12:37 am
You can use OpenVPN client to connect SoftEther VPN on iOS and Android.
http://www.vpngate.net/en/howto_openvpn.aspx#ios
gholam
Post by gholam » Wed Apr 03, 2013 10:55 am
thank you so much bro,
could you help me to config ovpen config ,?
I set all default setting in softEther on server
port is 5555 and l2tp key is "vpn"
I cant connect in openvpn config ,
could you hel me to fill it currect ?
i got this error :
Wed Apr 03 15:24:11 2013 TLS: Initial packet from [AF_INET]198.8.92.148:5555, sid=16022388 16128557
and wait...
Mahdi
Post by Mahdi » Wed Apr 03, 2013 10:00 pm
First of all active port 443 on your server then after generating the configuration file in the "openvpn/ms-ssttp setting" and the click "generate a sample .... clients" let open it by the notepad. in the line "porto" change "UDP" to "TCP" and in the line "remote" change the number to 443. Now import the profile to your client. Bear in mind that you do need an Open VPN client forgot native iOS, windows and Android client. I have tested it and it works nicely.
gholam
Post by gholam » Fri Apr 05, 2013 12:37 pm
Hi, Mehdi
I have installed opven vpn client and did all the mentinoed instruction by you
but it still cant connect
Please Help me on making it right
Mahdi
Post by Mahdi » Fri Apr 05, 2013 6:15 pm
Hi there
I should say your ISP is very important. I checked with asiatech and rightel and it works but today I was in a place with parsonline or Datak and I couldn't connect via openvpn. If you have some free port on your server let check some ports like 25 or even 80 just as a test let see whether you can connect via different ports or ISP. The problem in fact is about packet sniffing and port blocking in Iran. If you can connect to your sever through the softether native software your server setting in OK
gholam
Post by gholam » Tue Apr 09, 2013 4:58 am
thank you for your replay ,
could your please attach e open vpn config file from your server to I connect and test in shatel ?
and the let we see ...
p.s: normal vpn on L2tp via IOS is connect in IrancellWiMAX , just IOS .
emadneb
Post by emadneb » Thu Apr 11, 2013 3:00 pm
can I run L2TP VPN service and OPENVPN service at same time, and user decide to chooses wich kind of service want to use ?
