I've successfully setup SoftEther VPN as a remote VPN scenario. I'm able to logon to the remote network from a client and successfully ping the internal network interface of the SoftEther VPN server. However I'm not able to ping other hosts on the same network and subnet. I'm able to ping the other hosts from the VPN server itself so the connection should be OK. But if I try to ping these other hosts from my VPN client the connection requests time out.
I've used the L2 bridging feature from SoftEther to connect with this respective network,
Does anybody know what I'm doing wrong?
Robert
Able to connect and ping the int interf but no other servers
robertroos
Re: Able to connect and ping the int interf but no other ser
Did you use VM? If so, VM may limit packet.
