I've got the following question:
I run softether vpn (4.21 build 9613) on a few raspberry pi's 2 with Noobs-lite. Softether is behind a firewall and everything is running smooth.
For some users i would like to set a police so that they can not acces my local network, they may only use my internet connection for browsing.
I think i should use the polici rules for this users, but i do not know wich i have to use.....
Thanks in advance
Chief
User limitations
Re: User limitations
Please try to use access list function.
http://www.softether.org/4-docs/1-manua ... ccess_List
Chief
Thanks tisjun,
I will take a look at it.
Greetings
Greetings
Chief
unfortunately I cannot find what i am looking for.......what am I missing?
Thanks in advance
Chief
Thanks in advance
Chief
raafat
May you explain more ?, As has been suggested, your problem should be solved using a functionality called "Access List". So again, may you explain more ?
Good luck (:
Good luck (:
When you want to prohibit communication with hosts in the LAN except the gateway router, you should set the following rules to the access list.
* allow source MAC:<Router MAC address>
* allow destination MAC:<Router MAC address>
* deny all
* deny all
Chief
> Good luck (:
Sorry raafat, I didnt notice this post......
> * deny all
Thanks cedar this is it, MANY thanks :-)
Problem solved :-)
> Good luck (:
> * deny all
Problem solved :-)
