2016-07-10 10:25:18.586 [HUB "XXXX"] Session "SID-LOCALBRIDGE-1": Because communication has failed to be established with physical Ethernet interface "enp3s0", the Local Bridge has stopped.
2016-07-10 10:25:19.642 [HUB "XXXX"] Session "SID-LOCALBRIDGE-1": A Local Bridge connection to physical Ethernet interface "enp3s0" was started.
At reboot, the network adapter in not active.
I can fix this with "ifconfig enp3s0 up"
It comes up with an ip address assigned. I think this has something to with that I remove the ip address and ubuntu doesn't want to bring up an adapter without ip?
