I have a test config just about working with current Softether on CentOS 6.3.
1. I have a subnet of vpnpool users assigned to 192.186.250.1/24 from the local bridge to the OS's tap adapter. the OS's dhcp is successfully providing ip addresses to vpn users when connected. I can ping the ip address of the tap_vpn from vpn connected users and ping back the user's pool address from the vpnserver shell.
2. I have eth0 and 1 available in the LAN's subnet and can ping anywhere on the lan from the OS shell running the softether.
What I cannot figure out the best way to do is to bridge/route traffic between the tap_vpn and eth0/1. I am not sure if I can do this from the softether management gui or if I need to do this in the linux host OS. I would like to be able to filter traffic once the bridging is done.
Help with this probably basic step would be appreciated.
bridge softether vpnpool to lan
Re: bridge softether vpnpool to lan
What network address is used on eth0/1?
Is it same to VPN network address?
