Connection to softether L2tp/Ipsec from android unsuccessful
dhs9004
Post by dhs9004 » Sat Mar 10, 2018 7:58 pm
I'm able to connect from my PC using L2tp/IPSec, but when I tried from my android device it doesn't work. So I guess it isn't a port configuration.
I have a Sony phone with android 7.0 and I'm using Softether version 4.25 Build 9656
Thanks,
vlaryk
Re: Connection to softether L2tp/Ipsec from android unsuccessful
Post by vlaryk » Mon Mar 12, 2018 8:41 am
I was never successful to connect with L2tp/Ipsec from Android ICS (4.0.4)
But my Xiaomi Redmi Note (Android 7.0) connects just fine
Post by thisjun » Thu Mar 22, 2018 6:52 am
What OS does the PC use?
Is there any log in the VPN server?
Do the PC and the Android connect to the VPN server at same time?
dhs9004
Post by dhs9004 » Thu Mar 22, 2018 1:53 pm
Hi thisjun,
The PC OS is windows 7.
Yes, I have a password authentication.
I have tried different configuration, just the phone, just the PC and both, I also tried different
sequential like fist PC and then phone and vice-versa
Post by thisjun » Wed Apr 18, 2018 6:12 am
>I have tried different configuration, just the phone, just the PC and both, I also tried different sequential like fist PC and then phone and vice-versa
So, are there any difference of the results?
