remove soft ether
otto1357
remove soft ether
Post by otto1357 » Thu Apr 12, 2018 1:22 pm
I want to remove softether from my computer but when I use the control panel utility it says that !the set up program has been installed from outside the install source"
I have also tried simply delete the program or finding an uninstall utility in the files.
My next thought is to delete the register however I an not sure about it and want a complete uninstall, all files and data.
Can anyone help.
otto
Re: remove soft ether
Post by cedar » Fri Apr 13, 2018 7:55 am
I guess your installation database is corrupted.
Please overwrite SoftEther VPN software and then try uninstalling.
